Power steering reservoir location for 94' C220 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-21-2011, 03:53 PM Thread Starter
Date registered: Jul 2011
Vehicle: 94' C220
My C220 has recently started making the whiney noise while turning. I'm assuming it has to do with power steering? Can anyone tell me where I can find the reservoir to check if i need more fluid? I'm not very car savvy.
Also, off topic, I noticed something is making a rattling sound when I idle now. This is a very recent occurrence.
Help??
misslyssxo is offline
post #2 of 2 (permalink) Old 07-21-2011, 09:31 PM
Date registered: Jun 2009
Vehicle: 1991 300E
Well, the W202, the model series you have, was introduced in 1993 and came to the US in 1994. However, this site seems to acknowledge it only beginning in 1995. Somehow that doesn't seem right.
Nonetheless, you might do well to ask your question in the W202 C-Class Discussion Forum. I'm guessing that there weren't big changes in the engine and other items under the hood from 1994 to 1995.
More to the point of your question: You might try simply going to the full-service pump at a good service station and ask that they check the power-steering fluid and watch while they do it. If it is low, consult your owner's manual for the correct type to use in topping it off and don't over fill. However, I'm venturing a guess that it's more likely a loose belt and/or a loose mounting of the power-steering pump. Ask the attendant to give the pump a good shake and wiggle the belts if the fluid checks out ok. If anything's egregiously loose, it'll be readily apparent. While they're under the hood, with you watching, you should ask them to show you how to check the oil and transmission fluid also. Tipping the attendant a few bucks is appropriate for this level of attention.
A session under the hood with someone generally knowledgeable about cars could be very helpful to you.
Regardless of if it's fluid or loose items, you would do well to take your car to a trusted independent mechanic who is experience with Mercedes for service. Fluid shouldn't just disappear; if it's low there's probably a leak. Belts and pumps can come loose over time, but proper tension is important.
Welcome to BenzWorld. Enjoy your car. Please take the time to complete your profile, including year, model and location. That information can be very helpful to those who might offer help in the future.
300E91 is offline
    Power steering reservoir SLINWI W126 S,SE,SEC,SEL,SD,SDL Class 2 07-08-2010 02:22 PM
    Power Steering Reservoir location?E 320 blair771999 W211 E-Class 1 07-21-2009 03:38 AM
    Power steering fluid reservoir location? asc General Mercedes-Benz 1 06-13-2009 06:28 PM
    location of Power stearing Reservoir on E-500 Vince_E500 W211 E-Class 1 11-09-2008 09:27 PM
    Power steering reservoir tobyd W124 E,CE,D,TD Class 4 01-31-2006 10:17 AM
