Window wont work - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-21-2011, 09:01 AM Thread Starter
Date registered: Feb 2011
Window wont work
2003 ML320 window problem. Problem is rear window not going back up. Switch, motor, or regulator (or the part that goes from motor to glass)? Here is what mine is doing and how it started. I started to roll down my windows when one of the rear windows seemed stuck and made strange noise and then when down some, then pushed switch to make it go back up. Didn't go up. Now neither. Went around and used switch in back of console in back seat ---same thing. Now here is what i have not found in reading others posts. With my hands I can easily push the window back up or for that matter can push down. Feels as though nothing much is holding it up. Drove about a mile and the window slipped down about 3 inches. So now taped it closed so it will not just slip down. Any input as what part has failed, easy fixes (has to add that) or if it has came out of some track or whatever has caused this will be greatly appreciated. Thanks!
johnr319 is offline
post #2 of 2 (permalink) Old 07-21-2011, 06:49 PM
eric242340's Avatar
Quoted: 311 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
ERIC.
eric242340 is offline
One touch up wont work on passenger window domenico_169 C208/A208 CLK-Class 15 01-01-2011 12:25 PM
KEY FOB WONT WORK!! 1999 E300 Turbodiesel W210 E-Class 3 07-10-2010 09:55 AM
Power window wont work. 2000 C280 Sport W126 S,SE,SEC,SEL,SD,SDL Class 3 11-03-2009 06:05 PM
My suction door system wont work, my door dont close any more and my trunk wont work! amgeater W220 S-Class 4 03-24-2009 06:56 AM
After wire harness change temp gauge wont work, and now wont start daanmuller W140 S-Class 4 06-14-2007 08:00 AM
