mrs chibbens - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-20-2011, 02:16 PM Thread Starter
Date registered: Jul 2011
Unhappy mrs chibbens
hi ,help needed, i have a e300 td running fine untill now, was driving when she came to complete stop when the c. p. s. light came,she wouldnt start, left for an hour and she ran fine, switched her off and she wouldnt start, have changed the k40 and still no change, have noticed that when tempreture reaches 80 ish the cps light comes on then she stops then wont start untill cold again,could this be the crankshaft sensor. 1998 model also can someone give me help in locating crankshaft sensor, please most desperate
CHIBBENS1964 is offline
post #2 of 3 (permalink) Old 07-20-2011, 07:07 PM
eric242340's Avatar
Quoted: 300 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
ERIC.
eric242340 is online now
post #3 of 3 (permalink) Old 07-21-2011, 01:08 AM
eric242340's Avatar
Quoted: 300 Post(s)
I am not big on diesel engines but I believe this is the location, put your mouse over the attachment and left click to enlarge. Under the oil filter case just above the starter motor held in position by one torx head bolt and you will need to unplug the cable attached to it.
ID:	387476   Click image for larger version
ERIC.
