1996 E320 starting problems
802 views 2 replies 2 participants last post by  alle
I have a 1996 E320 Mercedes and I have a problem starting it, when I turn the switch to the 2nd position to start, there is a clicking sound in climate control area and the red and green lights on the rear view mirror start blinking, and if I keep trying the car starts just fine. :bowdown:
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
#3 ·
I have a 1996 E320 Mercedes and I have a problem starting it, when I turn the switch to the 2nd position to start, there is a clicking sound in climate control area and the red and green lights on the rear view mirror start blinking, and if I keep trying the car starts just fine. I checked the battery and the fuses, also the instrument lights willl go dim. I just don't know, please help.
