Hello from Tampa!!!
676 views 1 reply 2 participants last post by  eric242340
Hello Benzworld! Got an '82 380sl. Needs somd work, o2 sensor light isn't on before cranking the engine and it idles a little funny. I'm thinking it needs some tuning. How can I find out what I need to replace. I worked on an '87 Jetta and '89 Camaro quite a bit, but I'm a little intimidated with this ride. Taking the hard top off and putting the soft top on was a challenge, but I started working on a pulley system to remove it. Can anyone suggest the best parts store for my ride? online or brick.
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
