300SE failed smog with 15mph high HC - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-14-2011, 10:43 PM Thread Starter
Date registered: Jul 2011
Vehicle: 1991 300SE
My 300 SE failed smog today. Made sure car was warmed and up to temperature. Everything looked good. Only 125000 miles. Runs smooth no missing. Read out: 15mph: HC(PPm) max-105 meas-160 CO2 max-.49 meas-.38 NO(PPM) max-530 meas-1166. Any suggestions?
moyafotografx is offline
post #2 of 2 (permalink) Old 07-17-2011, 12:08 AM
eric242340's Avatar
Quoted: 296 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
ERIC.
eric242340 is offline
    Failed Smog Test in Ca (High NO) wireless-101 W201 190-Class 47 12-23-2016 11:38 PM
    Nearly failed smog: 300SE needs tune-up the_bends W126 S,SE,SEC,SEL,SD,SDL Class 3 05-31-2010 10:41 PM
    79 450 SLC failed Calif. smog - CO too high benzslcworld R/C107 SL/SLC Class 17 02-18-2010 04:42 AM
    Failed Smog test. High CO. How to lower CO? Sincity W201 190-Class 7 01-07-2009 08:09 AM
    Failed Smog ///M W201 190-Class 9 07-29-2007 10:21 AM
