Rough idle - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-09-2011, 11:32 PM Thread Starter
Date registered: Jul 2011
Vehicle: 1997 E300 Turbo Diesel
Question Rough idle
Hello All. I am a new member. I have a 1997 E300 W210 Turbo diesel. This is a comfortable car that really 'holds' onto the road. It is also very fuel efficient, delivering approximately 12kms/litre at the cruising speed of 110 km/h. It is a very good car to drive.
Recently I have noticed that the car is idling roughly when the motor is warm. It idles smoothly when the motor is cold, and also idles smoothly when in gear but with the brake pedal applied. So if I am idling at stop lights, it idles roughly, but if I put the car in gear and apply the foot brake to stop forward or reverse motion, it idles smoothly.
The problem was originally identified as a faulty EGR valve. This valve was replaced with a new valve, but the rough idle remained. This was not a good outcome, as the EGR valve was expensive and time consuming to replace.
I have cleaned the MAF sensor, but this has not altered the problem. I have read in this forum that faulty Oxygen sensor(s) may cause the problem, but I cannot find these.
Is there someone who has any ideas about how this problem may be fixed?
DavidW210 is offline
post #2 of 2 (permalink) Old 07-10-2011, 07:37 AM
eric242340's Avatar
Quoted: 312 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
ERIC.
eric242340 is offline
1993 300E 2.8 rough idle/stumbling/hesitation at startup/idle njb8199 W124 E,CE,D,TD Class 5 12-19-2010 02:57 PM
I figured it out running rough problem and idle rough danberg1 W126 S,SE,SEC,SEL,SD,SDL Class 11 07-21-2010 07:20 PM
260e rough start/rough idle/shudder CaprezMercedes W124 E,CE,D,TD Class 14 05-25-2010 01:36 PM
Low idle, rough idle, stalling, hot and cold start solved: E320/300 rvenerac W124 E,CE,D,TD Class 10 03-22-2010 11:28 PM
ROUGH IDLE, IDLE CONTROL UNIT LOCATION, TIMING & RPM verdejor General Mercedes-Benz 5 01-22-2006 08:41 PM
