head bolt torque - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-09-2011, 07:21 AM Thread Starter
Date registered: Jul 2011
Vehicle: c200k 2003 and 1991 e230
head bolt torque
help please
i have a 2003 c200k 2000cc oil in water system, head has been skimmed and parts supplied by merc all ok but i need the head bolt torque (i know the less than 105mm= 55Nm + 90 + 90 system) but my head bolts are about 175mm long and merc said i dont need new bolts but neglected to supply torque settings as asked. they now shut till monday: im rebuilding now and tonight, can anyone please help ta ray
rayinireland is offline
post #2 of 5 (permalink) Old 07-09-2011, 08:34 AM
Diesel Benz's Avatar
Quoted: 40 Post(s)
Originally Posted by rayinireland View Post
help please
You should give the VIN or better engine info, at least I did not want to go through the options to find the correct one. The first one I looked at had 45 Nm + 90 + 90 degrees.
Diesel Benz is offline
post #3 of 5 (permalink) Old 07-09-2011, 08:47 AM Thread Starter
sorry vin = wdc2030462r108261
head gasket part no = a 271 016 15 20
head bolts accesible after cams and carrier plate removed
thanx ray
post #4 of 5 (permalink) Old 07-09-2011, 11:10 AM
Quoted: 40 Post(s)
thanx ray
It is 45 Nm + 90 + 90, see attachment (I'll remove the attachment after a while).
Last edited by Diesel Benz; 07-09-2011 at 11:41 PM. Reason: removed the attachment
post #5 of 5 (permalink) Old 07-09-2011, 01:36 PM Thread Starter
thanks very much to diesel benz for your help. only timimg of cams left to do....
thanx again ray
Head Bolt torque specs confusion rlippincott W126 S,SE,SEC,SEL,SD,SDL Class 10 10-14-2013 09:11 AM
head bolt torque specs Braunhilda W123 E,CE,D,CD,TD,TE Class 4 07-14-2009 11:34 PM
head bolt torque question jdjones2001 W201 190-Class 0 06-19-2008 02:19 PM
oil leak...usual suspects?, head-bolt torque? Rickysa W126 S,SE,SEC,SEL,SD,SDL Class 3 01-31-2008 09:50 AM
M180 Head Bolt Torque unimogjohn Unimog 1 11-18-2005 05:53 PM
