How to re-tighten M111 cylinder head bolts? - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-09-2011, 06:06 AM Thread Starter
Date registered: May 2005
Vehicle: W123, W116 Wagon
Like to know how to re-tighten the head bolts.
The specs says 55NM + 90deg + 90deg (in a specific sequence starting from center)
Do I loosen a bolt, tighten to 50NM(41lbft), move to the next(according to the sequence) till I completed all the bolts , +90Deg to every bolt(according to the sequence again) and +90 Deg according to the seq?
Read that some just add another 1/4 Turn to every bolt (following the sequence).
Some say that torque to 82lb ft.
Which is correct way?
npk is offline
    Cylinder head bolts...which size needed? Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 8 04-03-2008 07:24 AM
    Need advice on cylinder head bolts Michael Pillay W126 S,SE,SEC,SEL,SD,SDL Class 11 02-04-2008 06:12 AM
    How to tighten the head bolts bigwiki W124 E,CE,D,TD Class 10 09-25-2007 12:59 PM
    Which is the correct way to tighten Head Bolts? W123 E,CE,D,CD,TD,TE Class 0 08-23-2007 01:39 PM
    cylinder head bolts origan W124 E,CE,D,TD Class 0 05-11-2007 06:00 AM
