Air Conditioner quick fix, left side warm... - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-04-2011, 06:46 PM Thread Starter
Date registered: Feb 2006
Vehicle: 2001-W210-CAPRI METALIC BLUE-/ 2002-W210 E300D
Location: Los Angeles, Ca, Aberdeen Scotland, Lawrence Ks.
Cool Air Conditioner quick fix, left side warm...
All;
I have a very slow leak in my air conditioner that will require major car dis assembly to repair. The dealer quoted close to 2,000 U$ to repair.
As an alternative I tri4ed and have been using for several seasons, a quick fix procedure. This process will add gas, and all important compressor oil to the system and makes it ice cold again.
Basically, I get a small taper hose, manually fill that hose with Mercedes Benz compressor oil, hook it up, then check the results on the climate display, freon pressure option.
The Pictures...
This shows a 210/E320 but is common to most Mb...
ID:	384754   Click image for larger version
ID:	384755   Click image for larger version
ID:	384756   Click image for larger version
ID:	384757   Click image for larger version
ID:	384759   Click image for larger version
ID:	384760   Click image for larger version
The finest example of automobile engineering in the world
Floats like a CADI
Stings like a BMR
Stingy as a Prius
and.... all Mercedes Benz.
MRBSMITH is offline
post #2 of 4 (permalink) Old 07-05-2011, 12:09 PM
Date registered: Dec 2009
Vehicle: 1997 E300D
Quoted: 20 Post(s)
Ya know, at the same store where you buy the 134a, they have a couple oz. oil charge in a can with enough 134a to purge the air out of the hose, then invert the can and force the oil in. No air, no mess. Just used one on my Mercedes.
I am a believer in adding some oil to leaky systems. In the past few years I have converted two R-12 systems to 134a. I was not able to find a drop of oil in the compressor or dryer of either system. Both worked fine after the conversion. The '78 Olds 98 has been sold, but the '86 Bronco is still working fine.
nelbur is offline
post #3 of 4 (permalink) Old 07-05-2011, 12:30 PM Thread Starter
Cool To me, the oil is...
the most important part. I was worried that MB had some secret type that I went to the dealer for that.
My car is trans climattal in that it spends fall and winter in the desert LA climate, and spring and summer in the hot humid mid-west. I need good airconditioning.
Does anyone know of any harfull effects if any of too much oil in a system??
I can't get a straight answer from the techs that I have talked to.
B
Floats like a CADI
Stings like a BMR
Stingy as a Prius
MRBSMITH is offline
post #4 of 4 (permalink) Old 07-05-2011, 12:37 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Good question. I am unclear from your DIY how many CCs of oil you typically add. I know you said you filled the tube but? I'm with you on using MB labelled oil. For that matter, is there anything special about MB 134a?
Musikmann is offline
    Binding noise in rear end (left/driver side) when accellerating and car is warm. sonicallyadept W123 E,CE,D,CD,TD,TE Class 3 07-30-2014 07:54 PM
    Air Conditioner Is Blowing Warm Air agent-tom W163 M-Class 9 06-12-2011 04:09 PM
    AC Blowing Warm Air Left Side/Cold on Right 430Driver W210 E-Class 13 05-17-2011 02:19 PM
    2007 E-350 Air conditioner blows warm air kmc2000 W211 E-Class 2 05-11-2011 11:02 AM
    Quick fix for A/C going warm! Benz-Friend W140 S-Class 13 08-05-2007 06:14 AM
