83' 300 TD Air Compressor Disaster - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-02-2011, 09:08 PM Thread Starter
Date registered: Jun 2011
Vehicle: 1983 300TD
Hi Everyone,
So on the heels of my first post and resolution of a glow plug issue I was driving my new wagon down the freeway with my AC on when WHAM! SLAP! BANG! A loud noise, hissing, screeching and all other kinds of chaos made me think I was in for real trouble...
I pulled off the freeway and after testing by driving up and down the street, listening, starting/stopping, and looking, I found the cause. My AC Compressor, the front most part of it, burst or broke or failed, but in any case now has a two or three inch popsicle stick sized piece of metal sticking off of it with an empty screw hole at it's end. As I drive it pivots and occasionally comes in contact with the fan. Additionally, on the front most part of the unit, behind a triangular steel plate, a circular steel plate is floating around loose, making a lurching noise. It really sounds terrible.
I only drove the car as far as needed to get it somewhere safe...now the thing is, there's a series of bolts around the front ring of the AC unit which I believe will allow me to pull out the broken parts if I loosen them. My plan is to do so in the morning so I can drive the car without that awful racket until I can fix or replace the unit, but I honestly don't know anything about these units, and don't want to damage anything...I don't care that if it works at the moment, just want to get back on the road ASAP...any thoughts? Thanks...
Vincent D is offline
post #2 of 3 (permalink) Old 07-02-2011, 09:30 PM
Kajtek1's Avatar
Quoted: 1070 Post(s)
Sounds like the center clutch bolt come off. Not such rare as you could expect. Make sure you didn't loose other parts in the process. You are lucky on older model you can take AC belt of and keep on driving. With serpentine belt it is impossible. Get new bolt and torque it per recommendations. Most likely thread locker will be involved.
Kajtek1 is online now
post #3 of 3 (permalink) Old 07-02-2011, 10:42 PM Thread Starter
Vehicle: 1983 300TD
Wow Kajtek1, thanks for the quick response and info...will take belt off in the morning, glad I don't have to start messing with the unit...for now...
    ANyone know how to replace compressor clutch on OM617 while compressor still attached to loss W123 E,CE,D,CD,TD,TE Class 16 06-22-2010 09:26 PM
    DIY Disaster B15M General Mercedes-Benz 27 02-21-2008 08:22 PM
    $15 5-in-1 air compressor for those that bought used SLKs with missing compressor Black98SLK230 R170 SLK-Class 2 11-29-2004 03:20 PM
    OMG... disaster... eastsidebenz W124 E,CE,D,TD Class 15 03-02-2004 11:05 AM
    S 600 disaster Guest (MBNZ) W140 S-Class 7 09-11-2002 08:20 AM
