trunk lock stuck- - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-27-2011, 11:25 PM Thread Starter
Date registered: Jun 2011
Question trunk lock stuck-
1985 mercedes 380 sl.the key to the trunk turns normally but the trunk will not open.i think the lock cylinder is broken, and i would like to know how to remove it for replacement or repair, must it be drilled out, or can it be reached by going through the back seat into the trunk?
thank you for your reply.
unit 322 is offline
post #2 of 2 (permalink) Old 06-28-2011, 03:13 AM
eric242340's Avatar
Quoted: 306 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
ERIC.
eric242340 is online now
    Steering lock stuck on? Or ignition lock?.....help! busters the boy! W124 E,CE,D,TD Class 21 05-12-2013 08:09 PM
    Trunk lock is not working Trunk locked shut Type 4 R/C107 SL/SLC Class 19 02-15-2013 08:30 PM
    1998 SLK: Top Stuck UP & Trunk Stuck Closed! karrnut R170 SLK-Class 23 03-26-2009 02:51 AM
    Help!! Stuck Trunk Lock on '88 300SL Doobster6 R/C107 SL/SLC Class 8 09-23-2008 04:50 AM
    sl55 in a cold garage for 2 weeks. trunk lock stuck help top wont go down mbnz3993 R230 SL-Class 1 03-09-2004 02:55 PM
