What's this electrical thing attached to Inline Injection Pump? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-27-2011, 02:08 PM Thread Starter
Date registered: Jun 2011
Hi I'm a newbie in the forum with an old Merc diesel. I've always been impressed how these keep on going year after year. The vehicle has always been a plodder, not very fast but always gets there whatever the weather.
Well up until a week ago anyway. She just refused to start. There's no fuel coming through to the injectors.
Is there a Diesel / electrical guru here who can identify what this thing does on the side of the Inline Injection Pump? There's some pictures attached.
I've ruled out the vacuum operated engine shut down device, it's not that. It seems like it's this electrical device with wires that's preventing starting. I have a hunch it's an immobilizer of some kind?
You can see a hexagon head bold attached to it, that's not standard. This is a long story, but in a nutshell a year ago the engine was replaced - which came complete with another injection pump. We had to salvage this electrical device from the old injection pump, because the new engine wouldn't start until this device from the old engine was present. Hence the hex bolt attached, because the retaining bolt was 'headless' - as a security measure to make it difficult to remove. Anyway that all happened a year ago, and the engine has been good as gold all this time.
The only issue over the last month or so is the yellow heater light taking longer to turn off, it never affected starting at all. I put that down to a blown glowplug. Can rule out glow plugs anyway because no fuel coming through, and the engine 'runs' and warms up while test spraying brake cleaner into air intake.
So what's this electrical device with all the wires for?
ID:	383618   Click image for larger version
dieselnutter is offline
post #2 of 3 (permalink) Old 06-28-2011, 03:59 AM
eric242340's Avatar
Quoted: 296 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
The bolt in the pic is not supposed to be there I believe, a bit of a diy mod.
Regards
ERIC.
eric242340 is offline
post #3 of 3 (permalink) Old 07-01-2011, 02:50 PM Thread Starter
I showed these pictures to my local Bosch Service centre and they told me everything I wanted to know and vehicle is running fine now
well of course it's a diy mod, that's what I'd said in the 1st posting if you read it.
    Brake inline pump rod jobe R129 SL-Class 1 02-09-2011 04:39 AM
    How's this thing attached and how do I get it back on? djoyce93 R/C107 SL/SLC Class 3 07-17-2010 08:35 AM
    inline fuel pump tenaus R170 SLK-Class 1 03-14-2010 03:05 PM
    250se injection pump (and bnz club injection repair manual) JJsAtoZatAz@MSN.COM For Sale/Wanted/Trade/Giveaway 1 02-19-2010 01:01 AM
    What is this...thing....attached to my oil filter housing? JMPhotography W126 S,SE,SEC,SEL,SD,SDL Class 8 11-16-2009 10:59 PM
