Broken Door - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-27-2011, 11:43 AM Thread Starter
Date registered: Jun 2011
Vehicle: 2006 C350 4matic
Broken Door
I broke the oem switch by closing the door on top of the belt buckle which crushed the switch. I pulled the pieces out and bought a replacement switch but the wire that the switch plugs into is too short and doesn't stick out enough for me to plug in the new switch. It seems that the only way to plug it in is to do it from the inside by pulling out the plastic trim that's behind the switch. I tried pulling it but it's not budging. I figured if I used any more force I'd break it. Do any of you guys know how to pull out that trim? Or is there an easier way to get this little door jamb piece in there? Thanks
djeloco1 is offline
post #2 of 2 (permalink) Old 06-28-2011, 12:52 PM
Musikmann's Avatar
Quoted: 5 Post(s)
It might help if you told us what year/model MB you have. Better yet, look for your native forum (scroll down until you see sedans, coupes, roadsters, etc.) and post this there. Good luck and welcome to BW.
Musikmann is offline
    Door Jamb switch sdoherty W124 E,CE,D,TD Class 16 11-24-2011 07:06 AM
    Broken Door Check...then electronics in door, related or not? Crazy4Benz General Mercedes-Benz 1 03-07-2011 09:25 AM
    06 C350 Door jamb switch. han607 W203 C-Class 2 08-16-2010 01:58 PM
    Door Jamb Switch broken 2nd time Passenger Door Yote W210 E-Class 1 05-27-2010 09:47 AM
    It's in the little details - updated door jamb switches MBeige W123 E,CE,D,CD,TD,TE Class 9 10-30-2007 02:00 AM
