Help!! 300e idle fluctuation - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-26-2011, 02:32 PM Thread Starter
Date registered: Jun 2011
Vehicle: 1991 Mercedes Benz 190E
Unhappy Help!! 300e idle fluctuation
My '87 300e with around 290k has recently, after initial start up in the morning, go back and forth between 500, and 2000 rpm. If I allow it to warm up, then shut her off, wait about 10 minutes to re-start, she runs fine the rest of the day, even after cooling down for several hours, until the next morning when the process begins again. I suspected a vacuum leak, but can not find one. Any ideas would be appreciated, Mike.
minermike2003 is offline
post #2 of 2 (permalink) Old 06-26-2011, 02:38 PM
Date registered: Jun 2009
Vehicle: 1991 300E
Search the W124 Discussion Forum. There are very few new or unique problems.
300E91 is offline
    1993 300E 2.8 rough idle/stumbling/hesitation at startup/idle njb8199 W124 E,CE,D,TD Class 5 12-19-2010 02:57 PM
    Voltage fluctuation at idle rnettleship W210 E-Class 2 04-22-2010 04:53 AM
    temperature fluctuation joemik W202 C-Class 11 08-23-2008 08:59 AM
    Temperature gauge fluctuation, irregular idle. Matthias W124 E,CE,D,TD Class 0 01-14-2006 12:19 PM
    300 E Oil Pressure fluctuation KermitF W124 E,CE,D,TD Class 4 03-01-2003 06:36 PM
