Compressor Clutch - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-26-2011, 10:35 AM Thread Starter
Date registered: Jun 2011
Compressor Clutch
I have a 2002 e320 4matic and I know the code 1419 is a faulty compressor clutch, could it be that the car is low on r134 and causing the clutch to refuse to engage. I am a new member and have already benefited from this site. Thanks for the help guys.
raoult54 is offline
post #2 of 3 (permalink) Old 06-27-2011, 06:50 AM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Yes low pressure will not allow the compressor to work, There is a pressure sensor in the system that actuates/sends the signal for the pump to turn on so better to have the system drained and vacuum and tested for leaks, if no leakes then recharge the system and take it from there.
eric242340 is offline
post #3 of 3 (permalink) Old 06-27-2011, 07:05 AM Thread Starter
Thanks Eric will do.
raoult54 is offline
    ac compressor clutch and the aux fan jet35a W201 190-Class 0 06-08-2011 11:03 AM
    ANyone know how to replace compressor clutch on OM617 while compressor still attached to loss W123 E,CE,D,CD,TD,TE Class 16 06-22-2010 09:26 PM
    Air con compressor clutch belchy V-Class 2 04-30-2009 09:49 AM
    Replace the compressor clutch alone, or the clutch and compressor... to loss W123 E,CE,D,CD,TD,TE Class 9 06-19-2008 01:59 PM
    A/C compressor clutch srfox W210 E-Class 5 04-06-2007 10:11 PM
