SL 320 Check Engine Light - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-26-2011, 07:11 AM Thread Starter
Date registered: Jun 2011
Vehicle: '97 SL320 Anniversary Edition (very cool blue!)
Hello, I'm Deborah and I especially would like to ask SL320Bill about a check engine light which came onto my car yesterday. I checked the manual and they discuss the transmission and I did experience a bit of a RPM surge while driving. Both brothers are gear heads and thought I possibly need a fluid change since I've had the car but drive occasionally (the other is a '2000 Jeep Wrangler) and haven't had the trans fluid checked or flushed. So, I'm guessing I need to have the system flushed and filled. I bought the car in "05 with about 70,000 miles and it's now a little over 100,000. Thanks guys (and girls).
SL320Deborah is offline
post #2 of 3 (permalink) Old 06-26-2011, 07:14 AM
eric242340's Avatar
Quoted: 311 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
ERIC.
eric242340 is offline
post #3 of 3 (permalink) Old 06-26-2011, 08:51 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
There are scores of potential causes for a check engine light and guessing only makes it worse. Aamco, as well as many auto parts stores will read codes for free, which will reflect what is actually wrong and thus the cause of the CEL. You can also buy a basic OBD-II code reader on Amazon for $30 if you don't want to be trapped.
If I had to guess, I would bet your CEL has absolutely nothing to do with your transmission.
As Eric says, please complete your profile. You may also find that you're close to a member with a code reader who'd be happy to give you a hand.
Good luck.
Check Codes is offline
How did My 300E Pass the Smog check with Check engine light? cdvyas W124 E,CE,D,TD Class 1 03-09-2011 07:43 PM
NO check engine light ? dead circuit ? ODBII shows event but light never comes ON resqav8r W210 E50 AMG, E55 AMG 2 03-11-2010 08:10 AM
Check Engine Light - How to check for codes? DesignEx W203 C-Class 2 03-02-2010 04:21 PM
1997 S420 Fuel gage light flasehs setting Check Engine light aljabari W140 S-Class 7 09-03-2007 09:19 PM
How to check code for check engine light 94 E320 W124 Synd W124 E,CE,D,TD Class 1 05-24-2007 02:37 PM
