W126 300SD Only one side of the seat switch works. - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-24-2011, 02:08 PM Thread Starter
wolfpl1947's Avatar
Date registered: Mar 2011
Vehicle: 1981 W126 300SD
Hi there, I'm having a problem with the passenger seat switch, only half of it works I know for a fact that all the motors in the seat work. The other day the whole switch worked but some one modified the the connectors by soldering them, I had some original wires so today I splice the wire and only half of the switch works. The reason why I spliced the wire is because; even though the switch worked the switch moved other parts of the seat so for example on the switch I moved the rear rest of the seat I would be moving the rear bottom of the seat, also the connectors weren't in the best shape. So I wanted to get in newer and not modified connectors and then worry about which switch movement would move which part of the seat. Now I'm faced with this problem. Do I have to solder the connectors like some one did before? Or is this another type of problem? I have cleaned out the switch it self but still nothing.
wolfpl1947 is offline
post #2 of 3 (permalink) Old 06-25-2011, 04:07 AM
eric242340's Avatar
Quoted: 306 Post(s)
You may get more response on this sub forum:
W126 S,SE,SEC,SEL,SD,SDL Class - Benzworld.org - Mercedes-Benz Discussion Forum
ERIC.
eric242340 is offline
post #3 of 3 (permalink) Old 12-02-2012, 05:06 PM
Benellipaul's Avatar
Date registered: May 2009
Vehicle: '84 300SD
did you ever fix that seat?
'84 300SD Turbo Diesel, '89 Honda VTR1000F, '68 Benelli Mojave, '82 Can-Am Sonic 500, '74 Kawasaki H1, '87 BMW K75, '82 Honda CB125, '03 Ducati 800SS and one opinionated cat ('97).
Benellipaul is offline
    Drivers side seat switch AmoS500 V-Class 0 06-12-2011 02:12 AM
    Looking for a Passenger power seat switch - 1981 300SD jusme W126 S,SE,SEC,SEL,SD,SDL Class 1 02-20-2010 07:21 PM
    300sd passengers side seat switch jeff d W126 S,SE,SEC,SEL,SD,SDL Class 1 07-17-2006 08:55 PM
    240D seat covers fit W126 300SD ? Extreez W126 S,SE,SEC,SEL,SD,SDL Class 2 03-11-2006 03:59 PM
    W126/300SD/SDL center console removal & window switch repair 300SDTURBOS W126 S,SE,SEC,SEL,SD,SDL Class 2 10-11-2004 11:48 AM
