Am I doomed to attend the dealer?????? - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 06-21-2011, 05:39 AM Thread Starter
fabslk007's Avatar
Date registered: Aug 2004
Vehicle: slk 2000k year 2000 and austin-healey sprite[bugeye]
Unhappy Am I doomed to attend the dealer??????
Hi guys, any help welcomed..I have a year 2000 slk 200k. I take great care of it, and I have it from new.Last Sunday for the first time ever it failed to start at the first attempt. The starter spun the engine well. Now this happens sometimes but not all the time. I replaced the fuel filter spark plugs and the fuel line pressure seems ok. Am I doomed to attend the dealer??? Any ideas of where to go next.
Thanks
Fab
fabslk007 is offline
post #2 of 13 (permalink) Old 06-21-2011, 06:51 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Thanks
Fab
Does it mainly happen when the engine is still hot or also with a cold engine?
Diesel Benz is offline
post #3 of 13 (permalink) Old 06-21-2011, 08:49 AM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
When you switch on the ignition to position 2, can you hear the fuel pump buzzing? If not, could be a fuse, relay or the pump itself.
Hooking up the OBD port to a reader may point you in the right direction.
MTI is offline
post #4 of 13 (permalink) Old 06-21-2011, 10:21 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 375 Post(s)
Hi. More information needed.
1. Did it start eventually? How did it run then?
2. You said "for the first time ever.." but also said "this happens sometimes but not all the time". What do you mean here?
3. How many miles, and is all servicing done?
4. When the engine refused to start, were there any error lights of the cluster?
5. Is your battery is good shape? How old is it?
6. When the engine refused to start - was it hot or cold?
keyhole is offline
post #5 of 13 (permalink) Old 06-24-2011, 04:59 AM Thread Starter
fabslk007's Avatar
Thank you so much for your response.Answer 1. When I turned the key the engine spun strongly for 4 seconds before 'catching'starting'. It ran perfectly. 2 .For the first time on Sunday, and then sometimes since then ,ie Monday Tues etc. 3. It is an old car (100,000 mls.)but maintained like new in every way. 4. No lights on. 5 Good battery.
6 both hot and cold. No codes have shown at my local (non main dealer) garage. The fuel filter is new, the fuel pressure is good, new plugs etc.
It runs brillantly on the road. I am kinda hoping it's the air mass meter, as I am told that it does not show up on faults? Realy thanks for reading this
Fab
post #6 of 13 (permalink) Old 06-24-2011, 05:00 AM Thread Starter
fabslk007's Avatar
Thanks ,no faults show, but thanks
Fab
post #7 of 13 (permalink) Old 06-24-2011, 05:01 AM Thread Starter
fabslk007's Avatar
Hi , the fault is there hot or cold.
Thanks
Fab
post #8 of 13 (permalink) Old 06-24-2011, 05:52 AM Thread Starter
fabslk007's Avatar
ligh
post #9 of 13 (permalink) Old 06-24-2011, 09:32 AM
Musikmann's Avatar
Quoted: 6 Post(s)
MAF sensor will throw a code (readable by the expensive scanners) but not necessarily a check engine light. If yours is original that's a reasonable place to start.
Musikmann is offline
post #10 of 13 (permalink) Old 06-25-2011, 07:16 AM Thread Starter
fabslk007's Avatar
Thanks for the reply, can a maf fault cause my troubles, do you think? My local garage showed no fault, but you suggest I go to the main dealer and it will show if it is the mfa or not? Thanks.
    We're Doomed DP Off-Topic 21 07-22-2009 10:13 AM
    Adventures In Identity Politics: Are The Democrats Doomed? Jayhawk Off-Topic 8 03-14-2008 03:25 PM
    drove 300D turbo without trans fluid. am I doomed? morav W123 E,CE,D,CD,TD,TE Class 10 01-18-2008 02:25 AM
    FTL, GS, Z What have you got to say ofr yourself now, you have doomed the earth..... Jakarta Expat Off-Topic 1 12-04-2007 05:30 AM
    Primer Pump Leaks...Am I Doomed?? JohnMcConnell W123 E,CE,D,CD,TD,TE Class 27 01-19-2007 10:20 AM
