C300 AC not working - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-18-2011, 07:48 PM Thread Starter
Date registered: Jul 2009
C300 AC not working
My 2008 C300's AC quit working this spring. The shop said everything looks good including the system being charged properly. Right now the driver's side blows 75 degree air while the passenger side blows 85 degree air. Neither side works but for some reason the passenger side is much warmer. The shop says they will need to remove the entire dash to look at the "blend door" which will be 10 hours of labor. Has anyone experienced a similar problem and had any luck resolving it?
brandonflees is offline
post #2 of 5 (permalink) Old 08-01-2013, 09:39 AM
Date registered: Apr 2013
Ahh Crap,
I'm having the same issue, please let me know if you get some reply from anyone.
divinebug is offline
post #3 of 5 (permalink) Old 08-03-2013, 07:55 PM
Date registered: Apr 2009
Vehicle: 1999 E300TD
A/C compressor issues can be pretty common, I have replaced many. The dash is not the first thing to take apart so don't listen to some crappy independent shop. The pressures have to be checked to see if the compressor is working. You can do a lot with the scan tool that we use at the dealer, it can check pressures and also check the blend door positions. Where are you located?
saleen1276 is offline
post #4 of 5 (permalink) Old 10-02-2013, 09:04 AM
I'm in Montreal, Canada. Can I buy this tool from somewhere?
post #5 of 5 (permalink) Old 10-02-2013, 04:04 PM
DrX's Avatar
Date registered: Aug 2006
Vehicle: 2002 ML320, 2003 A160
Quoted: 430 Post(s)
You can - it's not genuine but it does the same job.
DrX is online now
    1985 300D: Low-beams and foglights not working; all other lights working product42 W123 E,CE,D,CD,TD,TE Class 3 05-07-2011 10:17 AM
    Air Vents stop working, bang on passenger side dash board and it starts working... realog W202 C36 AMG, C43 AMG 2 10-12-2008 01:15 AM
    2009 C300 vs. 2008 C300 MY2008ML350 W204 C-Class 21 08-29-2008 01:48 PM
    C300 Luxury grille on C300 sport barolo red luckytruck W204 C-Class 9 06-29-2008 07:21 PM
    It is working!!! Modular Control System is not working after I changed battery di_mb W163 M-Class 0 12-27-2006 07:04 PM
