Service Update Wheel Mounting Saftey Check. - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-16-2011, 02:20 AM Thread Starter
Date registered: Jul 2005
Vehicle: 90 300E, 99 ML430, 00 ML320, 05 E500 4matic Wagon
Quoted: 886 Post(s)
Please see attached.
File Type: pdf SI40.10-P-0024A Check components for bolted wheel connection 2011.pdf (1.88 MB, 97 views)
Noodles is offline
post #2 of 3 (permalink) Old 06-16-2011, 10:30 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
It means the end of using antiseize compound on wheel hub faces to prevent the wheel and hub from "growing" together, as is so often the case. Hopefully the one approved location suffices.
And, it was obviously always the wrong thing to do to antiseize or otherwise lubricate wheel bolts.
Kent Christensen
'07 GL320CDI
lkchris is offline
post #3 of 3 (permalink) Old 07-03-2011, 04:47 PM
Date registered: Jul 2008
Vehicle: 2006 E350, 2000 E320, 1995 RRC, 2002 HD Fatboy
Originally Posted by lkchris View Post
...And, it was obviously always the wrong thing to do to antiseize or otherwise lubricate wheel bolts.
Kinda like greasing your brake disks do deal with 'squeaky' brakes? I knew a guy that really did that once.
pl626 is online now
    killing off saftey/emergency mode? Cemtey W210 E-Class 2 12-12-2008 02:06 PM
    Door Check Hinge Body Mounting Gene Horr W126 S,SE,SEC,SEL,SD,SDL Class 1 11-25-2008 06:55 AM
    Spare wheel mounting? hairyben V-Class 3 02-04-2008 03:08 PM
    Headlight knob saftey lock? DieselKraut W123 E,CE,D,CD,TD,TE Class 4 12-17-2005 04:38 PM
    Update of old news about the wheel mounting pin.......... William Monte W163 M-Class 9 03-10-2002 05:53 PM
