this site has saved me! - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-14-2011, 09:38 AM Thread Starter
Date registered: Jun 2011
Vehicle: 1995 SL500
i purchased a 95 sl500 a few years back. i was not a benz person but this car kept showing up in the parking lot of my office with for sale sign. i just couldn't resist. 45k original miles and perfect condition. since then i only had one problem. the Top Hydraulics started to leak. the dealer wanted $2000.00 to replace. i am not very mechanically inclined but do know that Hydraulic seals are not that difficult to replace (with the right tools). i starting searching and found this site.
I found Top Hydraulics and purchased a rebuilt set of Hydraulic cylinders with the lock assembly included. I did not want to pull the car apart and have too wait to get my cylinders rebuilt so i chose the option of paying a refundable core charge for the complete assemblies. this made the process so much easier and quicker. it only took about 1 1/2 hours from staret to finsih. was able to take a nice long ride the same day.
i have returned the cores and core refund will be issued as they receive. them. they even included a return priority mail envelope with everything needed for the return it was so easy i was sceptical but Top Hydraulics did everything they claimed. I even called Klaus for some advise and it was spot on.
i would add that if you need to flush your old fluid out of the system, suck the reservior dry then flush with new fluid. it will save you a quart or two of the new fluid. use a turkey baster and wash down the reservior a few times to remove the gunk!
thanks again for ther great site and kudos to Top Hydraulics. what a resource.
kklein is offline
post #2 of 2 (permalink) Old 06-15-2011, 04:37 AM
eric242340's Avatar
Quoted: 300 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
ERIC.
eric242340 is offline
    *SOMEONE HIT MY '2.6* but will it be saved? :-S 2.6_Steve W201 190-Class 33 04-17-2010 01:45 AM
    SAVED AT LEAST 20k HOPE W163 M-Class 3 03-23-2010 10:16 AM
    SAVED AT LEAST 20k HOPE C208/A208 CLK-Class 0 03-23-2010 01:26 AM
    My car might have been saved joelsec W126 S,SE,SEC,SEL,SD,SDL Class 12 01-23-2006 12:38 AM
    I just saved $4,000 ! Nektopoli R170 SLK-Class 2 05-23-2003 01:30 AM
