Hel[ with 1987 560 SEC Engine Swap - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-13-2011, 02:52 PM Thread Starter
Date registered: Dec 2010
Question Hel[ with 1987 560 SEC Engine Swap
Hello fellow Benz lovers and owners. I own a 1984 500 SEC and blew the engine. I have since then bought an engine from a 1987 560 SEC and did an engine swap. I was informed that the ignition module from the 84 will not start the engine from the 87. Can anybody please help me out and point me in the right direction?
MaseKidd is offline
post #2 of 2 (permalink) Old 06-14-2011, 07:32 AM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
eric242340 is offline
    1987 300E - Blower motor quit shortly after radiator swap xxx300e W124 E,CE,D,TD Class 31 03-13-2012 04:31 PM
    1982 300SD Engine/Trans swap into a 1987 300SDL? jusme W126 S,SE,SEC,SEL,SD,SDL Class 5 12-24-2009 03:39 PM
    ENGINE SWAP ... 1987 5.6 MOTOR AND TRANSMISSOIN INTO A 1985 500 SEL IRACE22 General Mercedes-Benz 1 11-17-2009 12:11 PM
    300e 1991 w/ engine swap 1989 - Engine Problem KillerTomatos W124 E,CE,D,TD Class 8 02-26-2009 03:54 PM
    1987 300SDL transmission swap IronManJohnBTW General Mercedes-Benz 0 01-02-2009 08:12 AM
