Which battery cable is positive/negative??? 450SLC 1980 - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-08-2011, 05:14 PM Thread Starter
Date registered: Jun 2011
Question Which battery cable is positive/negative??? 450SLC 1980
Hello,
So gotta admit, I'm pretty parallel when it comes to cars. However, I got stuck with a Mercedes 450 SLC from 1980...so why not use it??
First thing....it didnt have a battery. So I went to Walmart, flipped through their catalog and found/bought the battery.
I put it in the trunk (apparently thats where the battery goes on this model). Now, I know which end is + and which is - on the battery, but I am not sure which cable is + and which is - from the car to the battery.
I wanted to double check before I turn the key and cause any damage to the car or myself. I'll attach some pics for the fun of it.
The way the car cables are...there is a short one and a longer one. The way the battery fits, makes sense the short one is positive and long one negative but i wanted to make sure.
Thanks in advance.
ID:	379970   Click image for larger version
ID:	379971   Click image for larger version
varteju is offline
post #2 of 7 (permalink) Old 06-09-2011, 05:59 AM
Diesel Benz's Avatar
Quoted: 37 Post(s)
Originally Posted by varteju View Post
Hello,
Thanks in advance.
You don't have to wait until you turn the key, the damage has happened already before that (if you did not connect it right).
The battery poles are of different size, you can even try it as long as you try only one cable at a time. Better to check which one is attached to the body, that would be the minus (ground) cable.
Diesel Benz is offline
post #3 of 7 (permalink) Old 06-11-2011, 06:29 PM
Date registered: Jun 2004
Vehicle: 06 C230 Sport-6spd, 03 S500V4, 02 E320W4, 91 300CE, 89 300E, 95 C220
Suggestion: Do NOT shop at Walmart for parts for a Mercedes ... especially if you are not 100% sure of what you need, or what the vehicle requires.
With that aside, make sure the battery HOLD DOWN / TIE DOWN is still in place. You do not want the battery to be loose, or come loose during travel.
Steven Long, MBCA Delaware Valley Section
SDLong329 is offline
post #4 of 7 (permalink) Old 06-12-2011, 11:09 AM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
Just verify, as stated above, which cable is attached to the chassis ground/negative.
MTI is offline
post #5 of 7 (permalink) Old 06-12-2011, 04:24 PM
Date registered: Aug 2008
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 176 Post(s)
Using a multimeter
check each cable for continuity to a convenient body/chassis point. The ground (-) cable will show a short to that point. The positive (+) cable will not.
rocky raccoon is offline
post #6 of 7 (permalink) Old 06-12-2011, 10:44 PM
Quoted: 37 Post(s)
One would have to be careful with this method. Any consumer switched on would actually "short circuit" the positive cable to ground. It would not be exactly 0 ohm but could be difficult to figure out with an ordinary multimeter.
Edit: I did not feel necessary to post a new message but generally one should note that switching ignition off (which is most likely the case by default when the battery is disconnected) does not switch off all consumers meaning there can be significant load on the circuit 30 even if ignition is off. This is specifically the case for modern cars, on a 1980 SLC perhaps nothing remains on (if it does not have any alarm etc.).
post #7 of 7 (permalink) Old 06-13-2011, 04:26 PM
Quoted: 176 Post(s)
Of course.
This check must be done with ignition switch off and cables disconnected at the battery end. Trying to measure continuity on a line with voltage on it is likely to damage the multimeter.
    how do you remove entire positive battery cable huskerto W163 M-Class 5 10-31-2014 07:48 PM
    Battery Cable--560sl vs. 450slc reddfam R/C107 SL/SLC Class 3 03-30-2009 07:36 PM
    green powder forming around positive cable at battery. peregrine W140 S-Class 4 01-07-2008 07:02 AM
    Hydraulic Flush, Positive or Negative Pressure? G-AMG G-Class 8 05-08-2006 01:12 PM
    Does the negative battery terminal have a safety cover plate like the positive (red one) does? Darkmann W163 M-Class 4 01-17-2005 02:16 PM
