2004 C320 "Chirping" Alarm Goes Off for No Reason WHY?!?! - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-05-2011, 01:35 AM Thread Starter
Date registered: Jun 2011
Vehicle: 2004 C320 Sport Sedan
I just bought a 2004 C320 6-speed manual, V-6 sedan. I love it.
-Except that the alarm is incredibly unpredictable and goes off while I am away from the vehicle sometimes after 10 minutes or so. The sound is a very loud and inconsistent chirping. The alarm does not stop when I use the smartkey to unlock the car or insert the key into the ignition. It seems to have its' own brain. And, no matter what normal locking/unlocking procedure I follow I cannot rely on a consistent result. I took her to my mechanic who offered me a variety of explanations -but so far, no predictable solution.
Do I need to have the smartkey reprogrammed/batteries replaced?
Or, does the alarm itself need to be serviced (still under 3-month warranty)
Or, is there something I might be doing wrong in conjunction with locking with the smartkey/using the anti-tow switch?
I understand that the chirping might have something to so with a "Netherlands" setting..
donniedarko is offline
post #2 of 2 (permalink) Old 06-05-2011, 02:35 AM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
eric242340 is offline
    New pads/Rotors - "chirping" noise radman123 W163 M-Class 3 01-31-2009 04:04 PM
    New pads/rotors making "chirping" noise radman123 The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 01-28-2009 07:36 PM
    What is the right "CL" grille for a 2004 C320 Sedan? iaranovi W203 C-Class 7 11-11-2003 07:04 AM
    "Cricket -like" chirping noise - from LH side of dash area geordie W163 M-Class 5 04-15-2003 04:26 PM
