New Member from Seattle, WA with a problem
430 views 1 reply 2 participants last post by  eric242340
Hey guys, I'm new to the forum but I own a 1996 C220. Recently I was parked at home (extremely low on fuel) and when I tried to start it up a few days later, it would start but wouldn't idle. The startup seemed normal, but the frustration set in when it would seem to idle at all. I've done some research and it sound like it may be the fuel filter? The fuel pump sensor was changed back in 2008, and the cars been driven seldom since so I don't think it could be that. Does anyone else have an suggestions as to what I should do? Thanks
Problems aside I'm excited to be apart of this forum. I had never been a huge fan of Mercedes (I'm 21) but after owning this one for 5 years I have definite plans on owning other mercedes' in the future.
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
