Need help with transmission issue... - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-02-2011, 12:31 PM Thread Starter
Date registered: Jan 2010
I have a 1998 SLK230 with 80k mi. 3 weeks ago I'm parked on a 10 degree incline, nose up, over night. I go to drive off in the morning and cannot get out of first gear. I stop the car a mile away and move the shifter from drive back to park, then back to drive. When I shift back into drive there's a slight thud as the gear engages. I repeat the process 3-4 times, still getting the thud, when suddenly there's a smooth shift and off I go, however, the "check engine" light is on and stays on for a couple hours before disappearing. Since then I've parked at my usual spot and all seems fine.... until.... I park on the same incline location as before and the problem raises it's ugly head again. This time I don't drive off as far and was able to get the car back to normal shifting after a few attempts at moving the shifter back and forth. I'm not familiar with the "limp mode", but this seems hardly the issue given the abnormal jolt, albeit slight, that I've experienced. Perhaps I'm wrong. Can anyone point me in the right direction?
finrazor is offline
post #2 of 3 (permalink) Old 06-02-2011, 06:15 PM
Date registered: Apr 2009
Vehicle: 1999 E300TD
FIrst you have to get a scanner on it and see what code is being set for the check engine light. Sounds like a conductor plate issue thats located on top of the valvebody. Could be anything until you have the codes looked at. Get a scanner on it and also have the fluid level checked. Those transmissions leak constantly from the electrical connector pilot bushing
saleen1276 is offline
post #3 of 3 (permalink) Old 06-03-2011, 09:11 PM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
That is perfect advice, and most likely you are low on fluid (which you probably cannot easily check if the SLK is anything like the W202 with no transmission dipstick). Good luck!
-Marrs
The Coupe Group on Facebook
DirectLA is offline
    73 450 SLC Transmission issue 93shocarguy R/C107 SL/SLC Class 8 03-23-2011 08:21 PM
    Transmission issue? archiefan General Mercedes-Benz 0 07-31-2010 03:18 PM
    Transmission Issue wvcaudill W163 M-Class 31 04-20-2009 05:46 AM
    Transmission issue j1b3h0 W126 S,SE,SEC,SEL,SD,SDL Class 8 01-12-2009 08:12 AM
    Transmission Issue BC300CE W124 E,CE,D,TD Class 1 03-25-2007 06:20 AM
