insufficient charging--82 300TD - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-02-2011, 10:05 AM Thread Starter
Date registered: Jun 2011
The alternator on the 82 300 TD is not charging sufficiently to keep the battery charged. I have to charge it after every time I drive. AAA checked out the charging system, results: battery fine, drain only 0.2 amps (fine), cranking normal, car running battery voltage no load 13.940, 7.7 amps, loaded 13.120 minus 11.6 amps, the latter figure which barely is over the minimum for an OK rating. But it isn't good enough. Another post suggested cleaning battery ground (done), the connection at the alternator , and the engine to chassis ground, which it says connects to the chassis about where the drivers feet are. But I can't find it. Can anyone tell me where it may be, and make any other suggestions? Thanks very much.
jon77 is offline
post #2 of 3 (permalink) Old 06-02-2011, 10:26 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Check condition of voltage regulator/brushes.
Kent Christensen
'07 GL320CDI
lkchris is offline
post #3 of 3 (permalink) Old 06-29-2011, 04:21 PM Thread Starter
new regulator didn't solve it
Thanks, lkchris. After my first post the wipers quit. I replaced the regulator, brushes worn to about 1/3 length, but wipers still out and I am assuming that means the regulator didn't fix the problem. Wiper fuse is OK, I read somewhere that wipers going out can be a sign of alternator failure. Any other suggestions anyone may have would be appreciated.
jon77 is offline
    Charging, lights on dash - 300TD Ghaniba W123 E,CE,D,CD,TD,TE Class 9 12-12-2010 05:17 PM
    Alternator / Charging issues - may be OVER charging? SE7EN30 W220 S-Class 6 12-09-2010 04:48 PM
    84 300td charging issue mcslexus W123 E,CE,D,CD,TD,TE Class 7 10-25-2008 10:57 AM
    Insufficient trunk lighting... MBeige W123 E,CE,D,CD,TD,TE Class 10 04-10-2007 05:48 AM
    C43 Insufficient Power output. Need advice please. C43AUSTRALIA W202 C36 AMG, C43 AMG 0 11-25-2005 12:48 AM
