merc sprinter flat spot together with loud exhaust note - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-27-2011, 03:02 PM Thread Starter
Date registered: May 2011
Post merc sprinter flat spot together with loud exhaust note
hi can any one out there advise.i have a 2006 merc sprinter panel van witch sounds as i f the exhaust is blowing slightly on tickover, but it isnt cos i,ve checked.also after i,ve been travelling fast for a while then ease off then put the gas on again there is a momentary flat spot combined with a loud exhaust note.Could this be the dreaded egr valve sticking.the engine is the 2.1 311 cdi your comments would be very much appreciated. cheers
courier 5* is offline
post #2 of 2 (permalink) Old 05-28-2011, 06:27 AM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - - Mercedes-Benz Discussion Forum
eric242340 is offline
    Flat Spot The Pig W163 M-Class 5 02-08-2011 02:30 PM
    Flat spot in my 230K.... tclynes C208/A208 CLK-Class 3 06-17-2010 01:09 PM
    E220 Flat spot star garage W124 E,CE,D,TD Class 0 08-20-2009 02:46 AM
    flat spot papa W163 M-Class 2 06-24-2007 09:40 AM
    Flat spot 420 SE W126 S,SE,SEC,SEL,SD,SDL Class 2 09-01-2006 01:51 AM
