Hi new with a question about problems on my 1990 420 sel - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-26-2011, 02:31 PM Thread Starter
Date registered: May 2011
Post Hi new with a question about problems on my 1990 420 sel
hi im new on here and trying to find out whats wrong with my car. my fan wasnt working in my car so i removed the panel and made sure all contacts were clean on switches and looked under the hood at fuses and some connections. and now when i use my directionals my gas gauge flickers and when i tern on my headlights the arrows illuminate and the illumination goes off and when i use my directional it draws power from my panels where my lit up switches are. My sunroof doesnt work right now and when headlights are on if i hit the right directional the left on blinks on dash but outside the car the correct one isworking can anyone heeeellllpppp me ive been going crazy trying to figure out what i did
mercede is offline
post #2 of 3 (permalink) Old 05-26-2011, 05:04 PM
SaleenS7's Avatar
Date registered: Apr 2005
Quoted: 2 Post(s)
Welcome to the forums.
It sounds like you may have a short somewhere. Otherwise the wiring was put in the wrong place maybe? Are there any leaks inside your car? I'm thinking that water damage may be causing a short. Also try doing a search on this topic in the W126 section of the forums. Search bar is on the top right (almost right under your username and private messages) Maybe you'll come up with some info on this. If not you ought to copy and post this in the W126 section and someone there may be able to guide you.
SaleenS7 is offline
post #3 of 3 (permalink) Old 05-27-2011, 12:21 AM
eric242340's Avatar
Quoted: 295 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Regards
ERIC.
eric242340 is online now
    air condition problems 1990 300sl sl man R129 SL-Class 10 05-09-2013 04:45 PM
    300 E 1990 unknown problems...:( Abu_Issa W124 E,CE,D,TD Class 8 05-19-2011 07:38 AM
    COLD START PROBLEMS 500 V8 1990 MAYFAIR R129 SL-Class 14 05-31-2010 03:31 PM
    new 1990 500SL..with some problems hughjazz R129 SL-Class 26 11-10-2005 10:14 PM
