cabin filter c 350
811 views 2 replies 3 participants last post by  Mercedes Benz of Florida
Does anyone know how to change the cabin filter on c350? I was told filter is located behind glovebox. Not sure how to remove it to replace filter. Can't find any instructions online.
Thanks
under passenger side dash there is a black panel with 3 t20 torx screws...remove them and take the panel out...theres a large clip that holds the panel in place so use a light and dont break it...it will take a little rigging to sneak it out but you can also remove the kick panel to make it a lot easier..anyways when the panel is off theres a rectangle cover with two white clips that you slide and also 2 small metal clips that have to be removed...filter is under there...
