Help!! 1996 c280 cranks but no spark!!! - Mercedes-Benz Forum
post #1 of 23 (permalink) Old 05-21-2011, 08:15 PM Thread Starter
Spikec280's Avatar
Date registered: May 2011
Vehicle: 1996 c280
Exclamation Help!! 1996 c280 cranks but no spark!!!
Wats up forum! I reacently did an engine swap on my c280 every,thing fitted correctly,it was a m104 1995 motor that I put,into a 1996 c280. the problem is that the car spins but it,dont start,....the,ovp relay is good, new spark plugs,new bosch cables, I neeed serious help please! Thanks alot in advanced!
Spikec280 is offline
post #2 of 23 (permalink) Old 05-21-2011, 08:30 PM
eric242340's Avatar
Quoted: 309 Post(s)
Welcome to Benzworld. Check the crankshaft position sensor.
W202 C-Class - Benzworld.org - Mercedes-Benz Discussion Forum
ERIC.
eric242340 is online now
post #3 of 23 (permalink) Old 05-22-2011, 12:29 PM Thread Starter
Spikec280's Avatar
Vehicle: 1996 c280
is the 1995 crank sensor, diferent from the 1996 crank sensor?
post #4 of 23 (permalink) Old 05-22-2011, 06:00 PM
eric242340's Avatar
Quoted: 309 Post(s)
No, they should be the same.
ERIC.
post #5 of 23 (permalink) Old 05-23-2011, 12:02 AM Thread Starter
Spikec280's Avatar
Vehicle: 1996 c280
They do differ from each other .Name:  uploadfromtaptalk1306134135735.jpg
Sent from my SGH-T959 using AutoGuide App
post #6 of 23 (permalink) Old 05-23-2011, 12:03 AM Thread Starter
Spikec280's Avatar
Vehicle: 1996 c280
Here is the 95 one
post #7 of 23 (permalink) Old 05-23-2011, 12:09 AM
eric242340's Avatar
Quoted: 309 Post(s)
They do differ from each other .Attachment 376789
This one is for a newer model.
ERIC.
post #8 of 23 (permalink) Old 05-23-2011, 12:19 AM Thread Starter
Spikec280's Avatar
Vehicle: 1996 c280
So which one is the one that I need? The one I have installed right now isthe firt pic one...
post #9 of 23 (permalink) Old 05-23-2011, 12:21 AM Thread Starter
Spikec280's Avatar
Vehicle: 1996 c280
if I put the one in the second pic would it work?
post #10 of 23 (permalink) Old 05-23-2011, 12:37 AM
eric242340's Avatar
Quoted: 309 Post(s)
Here is the 95 one
On the right with the long cable is the crankshaft position sensor, lower centre of the pic is the camshaft position sensor and upper left is the air intake temp sensor and the final one top center appears to be the outside temp sensor.
ERIC.
    1996 C280 Replacing Spark Plugs under ignition coil Help kechow W202 C-Class 14 02-19-2012 09:16 PM
    1996 E320 Cranks but won't start. Help please! cam2009 W210 E-Class 13 02-12-2010 05:09 PM
    1996 E320 cranks but won't start ddilillo W210 E-Class 7 10-26-2009 08:47 AM
    Where are the Spark Plugs? 1996 C280 psdalton W202 C-Class 2 07-14-2007 06:44 PM
    1995 C280 Cranks but won't start after spark plug wire change 2000lotus W202 C-Class 1 06-18-2005 11:57 AM
