a class auto gearbox missing 6 & 7 gears help? - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 05-21-2011, 09:25 AM Thread Starter
Date registered: May 2011
Unhappy a class auto gearbox missing 6 & 7 gears help?
I have a class w169 auto 7g 2006. just had a gearbox ecu repair as it had a faulty rpm sensor. Now the ecu has been re-installed to car the auto box does not go into 6th and 7th gear.
It shows 6 & 7 on the dashboard display in manual mode but is not physically going into the 6th & 7th gears, all other gears are fine although they used to change down at 2000rpm they now change at 3000rpm. I have a couple of fault codes showing 0730 "A gear rotation on continuable variable is not permissible and in the engine ecu it shows"fault stored in y3/9nz cut control unit"
any ideas?
barn682 is offline
a class 160 semi auto with gearbox problems please help!! lottie1a General Mercedes-Benz 1 10-21-2010 09:39 PM
Will 411 crawler gears fit a 404 gearbox? Frank-cj421 Unimog 8 06-01-2008 09:28 AM
Gearbox selection bezel/display (the letters for the gears next to the gearstick) SEC380 W126 S,SE,SEC,SEL,SD,SDL Class 6 02-28-2008 09:25 AM
V280 GEARBOX OVER REVVING WHEN CHANGING GEARS socket V-Class 1 02-14-2008 01:38 PM
How to best shift gears on a manual gearbox meridivs W123 E,CE,D,CD,TD,TE Class 5 11-13-2005 01:33 PM
