2002 CL600 ABC Pump - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-18-2011, 04:00 PM Thread Starter
Date registered: May 2011
Post 2002 CL600 ABC Pump
I have a used 2002 CL600 that has 70k miles on it. I took it into the shop because there was oil on my garage floor. They told me it needed a new line and a hydraulic block. OK I paid for that took it home and the front left corner of the car started squeaking. I looked at the floor and more hydraulic oil on the floor. I took it back in they said the oil must have belched out the top of the tank and no problem but I need a new a arm and ball joints. OK I agreed to by that. They just called and said the ball joint and arm was in but my ABC pump would not recharge and my car was sitting on the tires and could not be moved and I need a new ABC pump. More thousands of dollars. They said when they put it on the lift the pump discharged and when they put it back on the ground and tried to charge it up it would not take a charge.
What is going on? Somebody help me understand. I have put 100 miles on this beautiful car in the last six months and have had it in the shop the rest of the time giving away $1,000 bills.
yokeltl is offline
post #2 of 2 (permalink) Old 05-18-2011, 04:16 PM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
I think they broke your car.
You "drove" the car back to the shop with the squeaking problem. Now the car can not be "moved".
Tell them to put it back the way it was when you "drove" it back the their shop the second time so you can "drive" it to the dealer to get it "fixed".
Document the mileages, symtoms, times, dates, ... Prepare to take them to small claim court.
mbvis is offline
2002 CL500 ABC Pump replacement alexgreggs C215 CL-Class 5 06-02-2015 05:44 PM
ABC/PS pump leaking causing ABC suspension severe drop 2003 s600 W220 S-Class 16 07-03-2012 03:54 PM
2002 S55 ABC pump/fluid - help bzliteyear The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 05-18-2009 03:17 PM
CL600 2003 W215 ABC pump sergeym5 C215 CL-Class 1 12-21-2007 12:17 PM
CL600 issues/ ABC and NAV Brilliant Silver C215 CL-Class 13 04-17-2007 07:07 AM
