1994 S320 Climate control fuse problem - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 05-10-2011, 07:11 PM Thread Starter
Date registered: May 2011
This is my first post here and I am fairly new to this. I have a 1994 S320 with a climate control fuse (#18) that keeps blowing. Initially it seemed to blow with the AC on or intermittently, but after checking a few components and disconnecting the aux heater motors and radiator fans etc, it now blows with the engine running. I have checked the wiring diagrams and the grey/red wire that goes to the aux motors, switching unit, pneumatic control unit etc, seems to be shorted to ground or something that is connected to it is shorting it. I have disconnected the auxiliary pumps, blower reg., radiator fans, fan relay, aux pump relay, internal air temp switch, pneumatic control unit (though I don't see a grey/red wire going to it). Anyone have an idea what is causing the grey/red wires to go to ground, or is there a common short location for this problem? I am going to get the service manual for the W140 tomorrow and have a look at the wiring diagrams there and start tracing the wires. I appreciate any help on this matter - I am not crazy about taking apart stuff looking for a short
Ray32825 is offline
    Heat Stuck on, Climate Control Panel/Climate Control Servo Problem? 123Doug W123 E,CE,D,CD,TD,TE Class 25 05-06-2016 11:40 PM
    1994 SL AC climate Control Panel problem...please help s132008 R129 SL-Class 3 11-24-2009 06:35 AM
    1995 S320 Climate Control problem jcberean W140 S-Class 5 09-24-2009 08:31 AM
    s320 climate control albert100 W140 S-Class 5 05-09-2009 07:07 AM
    Where is the Ovp fuse on a S320 1994 S3201994 W140 S-Class 1 09-26-2007 12:58 PM
