Gas lid lock - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-08-2011, 08:40 AM Thread Starter
Date registered: Apr 2009
Gas lid lock
My 2003 SL 500 has been garaged until recenly, with trickle charge. Been driving 200 miles or so and needed a fill up. Could not open the compartment. Wondering whether this is due to the elctronic system. More imprtanly, what is the fix?
whharris01 is offline
post #2 of 3 (permalink) Old 05-09-2011, 09:02 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Most Mercedes owners manuals contain instructions for manually opening the gas filler door from within the trunk.
If the mechanism is broken, the fix is a new one. Could also check electrical connections.
Kent Christensen
'07 GL320CDI
lkchris is offline
post #3 of 3 (permalink) Old 05-09-2011, 05:25 PM
Date registered: Dec 2009
Vehicle: 1997 E300D
Quoted: 17 Post(s)
If yours is vacuum operated, I suggest that you first spray silicone spray through the crack onto the pin that locks the door, and let it soak in overnight. The dry pin can develop so much friction that the vacuum motor can not retract the pin. Alternatively, spray the pin and pull on the emergency release as per your owners manual. Once it frees up, give it a shot of silicone once a year and work it to get the lube back inside the unit onto the o-ring or whatever causes so much friction when the rain washes the lube off.
All this assumes that you do not have a vacuum problem. The above fixed the unit on my E class which was inoperative when I bought the car used.
nelbur is offline
    Trunk lid lock disassembly? shingleback W201 190-Class 5 07-21-2006 02:16 PM
    Tonneua Lid won't lock London380sl R/C107 SL/SLC Class 1 06-09-2006 07:03 PM
    gas "lid" Michael Pillay W163 M-Class 1 04-19-2004 04:56 PM
    Trunk Lid Won't Lock Doug R170 SLK-Class 1 04-27-2002 03:40 PM
