MY CAR DOES NOT START AFTER FIXING THE SHIFTER BOX - Page 2 - Mercedes-Benz Forum
post #11 of 21 (permalink) Old 05-09-2011, 06:08 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 397 Post(s)
Please don't shout (USING UPPERCASE) - and your post is garbage...
Worn bushings do not prevent the start relay operating....
keyhole is online now
post #12 of 21 (permalink) Old 05-09-2011, 06:08 AM
Date registered: Feb 2011
Vehicle: 1997 Mercedes C230
I CAN ALMOST PROMISE THE SHIFTER BUSHINGS ARE BAD ON THIS CAR AND ITS NOT SHIFTING ALL THE WAY INTO PARK OR NEUTRAL. ITS A VERY VERY COMMON PROBLEM, AND YES THEY COULD. IF THE BUSHINGS ARE WORN AND THE PRNDL SWITCH ON THE SIDE OF THE TRANS IS IN R OR ANYTHING BUT P OR N IT WILL CASUE A NO START PROBLEM. THE PCM WONT ALLOW THE STARTER TO FIRE IF IT IS IN GEAR. AND IM NOT YELLING. IM ON A WORK PC THAT ONLY TYPES IN CAPS. SORRY. CHECK THE BUSHINGS IF IM WRONG IM WRONG, IF IM RIGHT I JUST SAVE YOU A SHIT LOAD OF MONEY
epictofer is offline
post #13 of 21 (permalink) Old 05-09-2011, 06:08 AM
eric242340's Avatar
Quoted: 309 Post(s)
Sorry chaps forgot to add, the fact that he gets reversing lights when not in reverse position shows that the shifter is messed up and needs looking at again with a trained eye.
ERIC.
eric242340 is offline
post #14 of 21 (permalink) Old 05-09-2011, 06:10 AM
keyhole's Avatar
Quoted: 397 Post(s)
In that case, the key will not be allowed to turn to the start position 3.
post #15 of 21 (permalink) Old 05-09-2011, 06:11 AM
eric242340's Avatar
Quoted: 309 Post(s)
Yes they can cause this but the car would run before he messed with the shift lever. The car must be in P or N and a fraction out will cause a no start situation. I also agree with the Please do not shout bit LOL
ERIC.
post #16 of 21 (permalink) Old 05-09-2011, 06:13 AM
eric242340's Avatar
Quoted: 309 Post(s)
On many models, the key will go to the run position but nothing will happen if the P position is not recognised.
ERIC.
post #17 of 21 (permalink) Old 05-09-2011, 06:38 AM
keyhole's Avatar
Quoted: 397 Post(s)
OK - I wasn't aware of that.
I did realize that the reversing light situation was also wrong, but assumed that was just another problem...
Regarding starting only being permitted in P & N, my understanding was that the DAS took care of that situation by releasing the steering lock, and only allowing the key to turn fully when those select lever conditions are met. Maybe not on the W210 class. That's why I suggested the CPS.
I'm prepared to be proven wrong though, especially as the OP has messed with the shift module.
post #18 of 21 (permalink) Old 05-09-2011, 06:45 AM
eric242340's Avatar
Quoted: 309 Post(s)
This is why I said on many models it will go to run but not turn the engine. MB has a whole mix of this over the years and models and can be confusing. For example on the W220 and W221 the key will go to the run position but if not in P then nothing will happen, not even a click. It also varies between the blade key setup and the EIS setup.
ERIC.
post #19 of 21 (permalink) Old 05-09-2011, 07:04 AM
keyhole's Avatar
Quoted: 397 Post(s)
My apologies to you Sir, for saying your comment was crap and you were shouting. It seems that you are possibly right here, and my comments are garbage.
Anyhoo, it's only a forum, and all comments are welcome, right or wrong!
post #20 of 21 (permalink) Old 05-09-2011, 07:31 AM
NO APOLOGIES NECCESARY MY FRIEND! THIS PLACE IS FER LEARNIN!! HOW EVER ITS DONE!
    shifter box dissassembly, help! dan-e-1991 W140 S-Class 4 11-21-2010 12:31 PM
    Bought a 1990 sl500 dont know where to start fixing zft325 R129 SL-Class 12 02-05-2009 07:20 PM
    old post but interesting, shifter box swapping skitzy.sht W201 190-Class 2 08-19-2007 05:25 PM
    Car won't start unless I fiddle with shifter..... jonsonneborn W124 E,CE,D,TD Class 8 04-14-2007 06:24 AM
    Fixing Glove Box Latch-- next step chuckg W140 S-Class 1 05-14-2006 02:12 AM
