Start error - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 05-06-2011, 02:12 AM Thread Starter
Nime's Avatar
Date registered: Jan 2009
Start error
1998 W168 A160 Petrol A Class 160.000 Km
I recently changed the key fob -plastic case only-. Remote lock functions properly. However I couldn't start the car. It did crank a second then now no sound engine when I try to start again. Battery is low but headlights are ok.
The electronic circuit seems not so complex, just a few simple chips. Why it's too expensive I don't know. I have no 2nd. key.
I repeat again there is no crank no sound when I tried. A guy from garage came and examined by hand/eye, tried to start then towed. I wasn't there.
I did no damage to transponder, just replaced the fob. Strange. Now I want to ask that if the key is malfunctioned, can diagnostic inform us?
Nime is offline
post #2 of 18 (permalink) Old 05-06-2011, 07:35 AM
Andrzejek's Avatar
Date registered: Jul 2004
Vehicle: 00 C-230, 04 C-240
The key FOB works on radio Frequency (RF) and InfraRed (IR). Both, RF and IR lock/unlock the car. But, the ignition only works with IR. I have had a problem with my key FOB where the lock/unlock worked fine, but the IR did not for starting the car (weak battery, dirty IR window on key and ignition).
Swap the batteries in the key FOB. Also clean the small, red windows on the tip of the key and the ignition switch on the dash.
If the key FOB is still not working, order a new one from Mercedes.
Replacing the ignition circuit is your last resort.
Andrzejek is offline
post #3 of 18 (permalink) Old 05-06-2011, 10:42 AM Thread Starter
Nime's Avatar
I'm not sure this key has infrared. I think spare key has no battery, if no battery then no infrared. According to Lofty, even key with empty batteries, engine will start, because of rfid.
I noticed there is a white plastic piece inside the original fob which one couldn't fit Chinese remake, so I throw it. I don't know it's purpose, maybe it's a useful thing when blade is opened.
Nime is offline
post #4 of 18 (permalink) Old 05-06-2011, 11:10 AM
Kajtek1's Avatar
Quoted: 1163 Post(s)
The big circuit board inside the key is for locks and alarm only.
Ignition chip is about 2mm diameter mounted in the tip of the key.
I understand that you replaced lock remote into new case, but the ignition chip is still in the old one?
Now it would be a good time to buy spare key.
Kajtek1 is offline
post #5 of 18 (permalink) Old 05-06-2011, 01:51 PM Thread Starter
Nime's Avatar
OMG, that plastic piece would be RFID?
Edit: OK, this is the RFID which I did throw
Nime is offline
post #6 of 18 (permalink) Old 05-06-2011, 02:14 PM
Kajtek1's Avatar
Can you post a picture of old open case?
Kajtek1 is offline
post #7 of 18 (permalink) Old 05-06-2011, 02:18 PM Thread Starter
Nime's Avatar
I'm gonna buy most expensive rfid in history...
Nime is offline
post #8 of 18 (permalink) Old 05-06-2011, 04:29 PM
Kajtek1's Avatar
You have some reddish stuff covering something in right lower corner. I believe this is the chip.
Kajtek1 is offline
post #9 of 18 (permalink) Old 05-09-2011, 05:16 AM Thread Starter
Nime's Avatar
Nice. Dealer asked me 325€ and 15 days for a key.
Nime is offline
post #10 of 18 (permalink) Old 05-10-2011, 01:07 AM Thread Starter
Nime's Avatar
Nime is offline
    start error bonta V-Class 42 08-12-2011 07:43 AM
    Start error Mk85 General Mercedes-Benz 2 11-16-2007 06:25 AM
    Start Error !!!! timer W168 A-Class 2 12-28-2006 02:53 PM
    Start Error drkonek W163 M-Class 6 10-01-2006 10:19 PM
    Start Error Hugo R170 SLK-Class 0 11-10-2002 04:26 PM
