Help!!!! - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-06-2011, 12:38 AM Thread Starter
Date registered: May 2011
Help!!!!
my e320 suddenly developed a knocking noise in the engine, between the timing chain cover and the timing chain was a piece of metal. What can that be? The object (metal piece) fell through to the sump but the knocking sound is still there.
BarneyLu is offline
post #2 of 5 (permalink) Old 05-06-2011, 08:47 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Gear tooth, tensionor rail stuff, etc. Inspect.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #3 of 5 (permalink) Old 05-06-2011, 02:16 PM
Kajtek1's Avatar
Quoted: 1198 Post(s)
picture?
Kajtek1 is offline
post #4 of 5 (permalink) Old 05-08-2011, 01:38 AM Thread Starter
this is the parts i found
ID:	374190   Click image for larger version
BarneyLu is offline
post #5 of 5 (permalink) Old 05-08-2011, 10:15 AM
Kajtek1's Avatar
Spring is most likely part of chain tensioner, so logically the other parts are coming from there too.
I am not familiar with chain tensioner on 320, but on our diesels it can be unscrewed and removed on the side on the engine. All it takes is big wrench.
If you are lucky -putting new tensioner will solve the problem, if not -you might need engine rebuild. Keep your fingers crossed.
Kajtek1 is offline
