1979 450SL - Air Slide Valve Operation/Check - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 05-05-2011, 07:12 AM Thread Starter
Date registered: May 2011
Hello:
I have removed the air slide valve from my car (Bosch 0280140), and tested it (I think) by immersing it in hot water. I noticed only one air port did indeed attain an almost fully closed position (open maybe 1/16 inch) when heated, and opened when cooled. The other port, regardless of temperature, remained fixed at a half-open/closed position. Is this normal operation?
Should both sides of the ports have opened and closed equally?
Also, on the "stuck" port, the upper portion of the sleeve where the pistion slides appears damaged/rough edged.
SYMPTOMS of car: Good cold start; as engine warms, idle decreases continuously until engine surges, almost stalls. In fact, engine has stalled, but not always, after driving and coming to a stop, especially with AC on, and engine temps. near 212 (I live in Arizona, where almost everything is always 212). Engine sometimes diesels a little upon shut down, especially when hotter.
Could faulty air slide valve (too much air) also be a reason for the car to be running warmer than normal?
If it is a faulty air slide valve, can anyone recommend where to get one? I've seen them listed on e-bay for about $150.00 (refurbished?), and brand new for $370.00. Either way, yikes.
Thank you for your help,
Berdo
Berdo is offline
    Auxilliary Air/Slide Valve Deconstructed rowdie R/C107 SL/SLC Class 34 02-05-2016 12:04 PM
    Air Slide Valve...? MartynGrattage W123 E,CE,D,CD,TD,TE Class 10 03-18-2013 05:23 AM
    Idle control valve/air slide valve question dcrews R/C107 SL/SLC Class 5 05-24-2010 01:54 AM
    Air Slide / Idle Air Control Valve iglobalflyer R/C107 SL/SLC Class 5 08-28-2009 01:25 PM
    Question about the air slide valve on a 450 SEL robertjans Vintage Mercedes-Benz 1 05-19-2004 08:51 PM
