2002 S430 Xeon Lights help! - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-04-2011, 04:18 PM Thread Starter
Date registered: May 2004
Send a message via MSN to mrvegas
I just got 2002 S430 and a bit confused what kind if HID kit I should get to get the closest to the OEM HID.
My car has OEM HID's, so my question is what HID kit I should get to get the closest look to the OEM HID, and also, do I need to change the headlights to something different to support HID bulbs?
Thank you in advance
mrvegas is offline
post #2 of 2 (permalink) Old 05-08-2011, 03:43 PM
StarPower's Avatar
Date registered: Oct 2009
Vehicle: 2003 Lincoln LS V8
You don't need a kit. HID kits are designed to convert halogen headlights to HID. Since your car already has OEM HID's, all you need are D2R bulbs. I'd recommend sticking with a major brand like Osram, Phillips, or GE. Since the bulbs colorshift (become bluer and dimmer) as they age, it's best to replace them in pairs so that both bulbs match.
You won't need to change anything in your headlights to install them. Just remove the plastic cover on the back of your headlights, then twist the ballast (metal box) 1/4 turn CCW and pull it off. You can now pull out the old bulb and slide in the new one. Be careful not to touch the glass part of the new bulb with your fingers (gloves are a good idea) because the oil from your fingers can shorten the life of the bulb.
StarPower is offline
    Mercedes C220 diesel - Xeon lights & rear lights not working? Decay W203 C32 AMG, C55 AMG 0 12-20-2010 09:08 AM
    source for xeon inner driving lights? E55pvan W210 E50 AMG, E55 AMG 25 03-21-2005 10:20 AM
    xeon lights or projection (in-pro) for e320 2000 help mrhappy71 W210 E-Class 16 09-14-2004 05:11 AM
    Upgrading to Xeon Lights DinoBenz W220 S-Class 0 08-19-2004 04:37 AM
    xeon lights gary1378 W163 M-Class 3 04-12-2004 06:03 AM
