'93 230E W124 idling problem - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-04-2011, 12:33 AM Thread Starter
Date registered: Apr 2010
Vehicle: 1993 Mercedes Benz 230E W124 Manual
Send a message via MSN to tec_hno07
Post '93 230E W124 idling problem
Hi,
I have a '93 Mercedes Benz W124 Manual. i have noticed that the car stalls when it is stationary and a gear is engaged. It does not stall immeadiately it will take about 15 seconds, but if in neutral it will idle normally.
It stalls in gear only if the clutch is engaged, so if i am creeping along in traffic it will stall, therefore i have to constantly drive forward and put into neutral to prevent the car from stalling, this solves the problem but is very irritating.
does anyone know what is causing this problem?
tec_hno07 is offline
post #2 of 3 (permalink) Old 05-04-2011, 01:03 AM
eric242340's Avatar
Quoted: 306 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Regards
ERIC.
eric242340 is offline
post #3 of 3 (permalink) Old 05-04-2011, 10:07 AM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
Welcome!
Try doing a search in your cars specific forum and see if others have had the same issue as you.
W124 E,CE,D,TD Class - Benzworld.org - Mercedes-Benz Discussion Forum
1979 Pontiac Firebird 5.7- 86,142 miles
1981 Chevrolet Corvette 5.7
1984 Mercedes 190D 2.2 Auto - 140,628 miles
1987 Chevrolet Sprint 1.0 - 139,000 miles
1989 Oldsmobile Cutlass Calais S - 123,000 miles
1989 Chrysler New Yorker - 95,000 miles
1991 Dodge Stealth R/T - 101,000 miles
1999 Dodge Durango - 178,000 miles
2003 Dodge Dakota - 203,000 miles
1984babybenz is offline
    W124 E200 Idling Problem Graham. General Mercedes-Benz 1 12-24-2011 07:55 AM
    Idling problem with w124 m102 engine bigboy99 General Mercedes-Benz 1 01-25-2011 09:38 AM
    w124 230e transmission problem? rollzon20z W124 E,CE,D,TD Class 1 06-07-2008 03:49 AM
    have the problem about heat in W124 230E tsattaba W124 E,CE,D,TD Class 2 10-11-2004 08:52 AM
    W124 - 230 2.3e Idling problem MarkB W124 E,CE,D,TD Class 4 09-21-2002 07:40 AM
