W124 - Dash dial stops working when i put car in gear - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-26-2011, 02:33 AM Thread Starter
Date registered: Apr 2011
Hi.
Can anyone offer any suggestions? When i turn on the ignition on my 'M' reg E300 W124 Estate, everything is fully operational. As soon as i put the automatic into gear, the dial with the temperature, oil and fuel gauges cuts out and the audible buzzer comes on (very irritating !! ). Initially thought a fuse was playing up, but then realised it was cutting out when putting car in gear...
Have recently replaced the small LED bulb in the gearbox housing and was wondering if i have distrubed something under there that could be causing this? problem did not start until some days after bulb replaced...
Help... anyone recommend anything??
Shaz
Shazza is offline
post #2 of 3 (permalink) Old 04-26-2011, 07:54 AM
SaleenS7's Avatar
Date registered: Apr 2005
Quoted: 2 Post(s)
Have you opened it back up to check the condition of the wiring and connections? Maybe you accidentally nudged something out of place. Sounds like a simple problem.
If I were you I would post this in the W124 section of the forums. Other W124 owners might be able to help you out in more detail.
W124 E,CE,D,TD Class - Benzworld.org - Mercedes-Benz Discussion Forum
SaleenS7 is offline
post #3 of 3 (permalink) Old 04-26-2011, 06:55 PM
eric242340's Avatar
Quoted: 312 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Regards
ERIC.
eric242340 is offline
New battery put in, now dash lights not working? benzml350girl General Mercedes-Benz 1 01-14-2011 10:05 AM
W163-the car is in PARK and can't put it in GEAR ckub52 W163 M-Class 15 12-29-2010 01:01 AM
Cabin blower stops working once the car is running- Any idea whats wrong? inky W201 190-Class 3 12-16-2010 05:40 AM
Car stall when put in gear....HELP!!! TheFinestImage W140 S-Class 20 06-27-2007 08:21 PM
Unknown dial on dash Chas G-Class 10 06-28-2002 03:54 PM
