v-12 eta wiring questions - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 04-22-2011, 08:02 PM Thread Starter
Date registered: Apr 2011
1995 cl600.I found the info @ v-12 uber alles for rewiring the throttle actuators.Not only are the colors all different,The driver side (u.s) seems to have 2 wires different.seems that on the circuit board cavity j and i are crossed.has any one else experianced this??I checked and wrote down my own diagram,then found this stuff from v-12 uber.I rewired it using my notes and I still have a problem with the passenger side eta not working and engine has no power.Trying to figure out if I did something wrong or maybe the sensors in the eta are bad.I rewired the passenger side first,If I started the car enough times it would work sometimes.(just as before)After the driver side rewiring job,It won't do that at all now.My only uncertainty is the j and i.Is the diagram on v-12 ulber 100% correct on all models/years?should I try switching the j and i.after looking @ all this stuff,maybe I made the mistake.Thanks for the help.
stylin is offline
    1993 300E 2.8 upper wiring harness, ETA wiring insulator, and OVP relay ohman W124 E,CE,D,TD Class 31 05-13-2011 02:00 PM
    Toyota recall and Mercedes-Benz engine and ETA wiring KBelov W124 E,CE,D,TD Class 23 04-08-2010 11:48 PM
    Is it safe to change wiring harness without changing ETA? MaxMatt W124 E,CE,D,TD Class 7 01-23-2009 09:48 AM
    New info. ETA wiring lesrrt W140 S-Class 16 09-27-2007 01:08 PM
    S600 lh ETA wiring diagram needed defender W140 S-Class 1 08-28-2007 10:41 AM
