slipping timing chain help needed - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 04-22-2011, 07:05 AM Thread Starter
Date registered: Feb 2011
I recently bought a 2006 c180 k estate with a blown motor .I purcased a used motor from a used spare dealer in cape town (104000 kms ). I fitted the motor and began to crank it to get oil pressure . It cranked fine but sounded like one cylinder was down on compression .It then stopped cranking and seemed seized .tried again same thing .I then turned it over by hand and heard a noise from the cam gear area . We removed the cam cover and noticed the timing chain was riding up and slipping a tooth when turning the engine(intake cam ).the engine looks good in side and the oil and filter where clean .My thinking is a stuck valve adding extra ressistance on the cam and therefor pushing the tensioner back alowing the chain to slacken and slip teeth .Can anyone help advise .Can anyone recomend a mechanic in cape town sa who could have a look .I really dont want to take the engine out again pease help reg Robin
robincoss is offline
    Help needed with timing chain chiro W201 190-Class 4 09-28-2010 02:18 PM
    help needed in splitting the timing chain on a Vito fredthebread V-Class 3 05-05-2010 08:25 AM
    Timing chain help needed sat1962 W126 S,SE,SEC,SEL,SD,SDL Class 18 12-24-2009 01:10 PM
    Timing Chain Advice, Help Needed streetrules W123 E,CE,D,CD,TD,TE Class 0 07-16-2005 12:14 AM
    parts needed to fix timing chain ibrahim83 W126 S,SE,SEC,SEL,SD,SDL Class 5 10-09-2003 06:16 AM
