7 Speed Transmission Question/Problem - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-20-2011, 07:51 PM Thread Starter
Date registered: Jan 2011
Vehicle: 1991 300D 2.5 Turbo 263k, 1993 300D 2.5 Turbo 280k, 2007 GL320CDI 4Matic 100k, 2007 E320 Bluetec 65k
I have a 2007 GL320 CDI and a 1991 300D. Ever since day 1, the GL has a weird characteristic the 91 does not. In the 300D, when letting off the accelerator at about 25-45, the transmission goes into a 'neutral' mode and idles. The GL however, does not do this. When the accelerator is let off, it just holds the gear and pretty much loses velocity because the gear is still hooked up. This can get annoying at times and I just wanted to know if this is a normal feature of the 7spd or if I have to do something to it to fix it. Thanks.
STPilots5150 is offline
post #2 of 2 (permalink) Old 04-21-2011, 09:29 AM
millpond's Avatar
Date registered: May 2010
Vehicle: 2007 SL 550, 50th Anniversary Edition
This is how my 7 speed works too. Perfectly normal.
millpond is offline
    722.9 7-speed transmission problem. zhuorongdeng General Mercedes-Benz 86 12-25-2014 09:47 PM
    Transmission Problem? 99 SLK 230 5 speed Rgroat R170 SLK-Class 6 08-10-2012 05:37 PM
    190e 5 speed manual transmission problem 190EEEE W201 190-Class 5 04-09-2009 07:13 PM
    Problem with 7 speed transmission in 2005 500e wassguy W211 E-Class 3 07-21-2007 09:24 AM
    7 speed transmission, problem wassguy General Mercedes-Benz 1 07-18-2007 11:51 PM
