Reverse gear not working - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 04-18-2011, 03:27 AM Thread Starter
Date registered: Nov 2009
Vehicle: W202, 1995, C200 Sport
Any idea as of why my reverse gear doesn't always work? 1 of 10 times I put it in R it's as if the tranny thinks it's in Neutral. No movement..
Is there any way of testing what's wrong? I'd hate to take it to an expert only to pay thousands just to find out I need a new tranny.. thanks!
haz_norway is offline
post #2 of 12 (permalink) Old 04-18-2011, 03:41 AM
Date registered: Jan 2009
Vehicle: 1994 C280
Sounds like a faulty shifter.
Does it reverse up a hill fine when it does engage reverse?
c280esprit is offline
post #3 of 12 (permalink) Old 04-18-2011, 05:53 AM Thread Starter
faulty shifter, how so? (I'm blank on transimssions, so please enhance why you think so )
Yes, when "it hits the gear" (which it usually does) it pulls fine.
Every forward gear is super duper smooth and its shifts as new.
post #4 of 12 (permalink) Old 04-18-2011, 08:38 AM
1984babybenz's Avatar
Vehicle: 1984 190D 2.2
Is this for your w202? What year/ model?
1979 Pontiac Firebird 5.7- 86,142 miles
1981 Chevrolet Corvette 5.7
1984 Mercedes 190D 2.2 Auto - 140,628 miles
1987 Chevrolet Sprint 1.0 - 139,000 miles
1989 Oldsmobile Cutlass Calais S - 123,000 miles
1989 Chrysler New Yorker - 95,000 miles
1991 Dodge Stealth R/T - 101,000 miles
1999 Dodge Durango - 178,000 miles
2003 Dodge Dakota - 203,000 miles
1984babybenz is offline
post #5 of 12 (permalink) Old 04-18-2011, 12:36 PM
Vehicle: 1994 C280
HAHAHAHA. I had a bit of a dumb moment - i was tired. I meant faulty SELECTOR not shifter.
i.e the thing with P, R, N, D, 3, 2,
post #6 of 12 (permalink) Old 04-18-2011, 11:55 PM Thread Starter
hi again guys, yes this is for my 96 W202 C200 automatic. I had a chat with a buddy last night, and he told me there could be some dirt stuck in the valves inside th etranny, so I tried to gun it it reverse and then quickly let go off the gaspedal. In that way some potential dirt would let go and get suck down through the valves.. probably didn't do any good but I did that five or six times just to have tried it.
How do I seek after where the fault is located? I know Mercedes have the possibility to hook it up to their system and go through the codes, but is there any way of doing something similar myself?
c280espirit; I figured But, how can the selector itself cause this, and why only Reverse? Can this be caused by someone spilling a few drops of some drink or other liquid by mistake? So that it shortcuts from time to time?
This seems to be "communication problems" and not mechanical, right? Because it regurlarly works, but when it doesn't, maybe it it's because there's an electrical fault somewhere?
Is there a point of removing the connector on the tranny itself and mabye clean the points?
Sorry for posting here, I didn't recieve any response in the W202 forums, or maybe I wasn't patient enough.. thanks for any replies on this.
post #7 of 12 (permalink) Old 04-19-2011, 01:51 AM
Vehicle: 1994 C280
im not to sure as to how the selector actually works but i do know that a person here that had a similar problem but with drive. He said he replaced the selector and the problem was fixed.
post #8 of 12 (permalink) Old 04-19-2011, 03:00 AM
Vehicle: 1994 C280
Originally Posted by zone.zo786 View Post
It has to be one ************ of a hill to clutch start in reverse with nobody pushing... basically its about the same as clutch-starting in 1st gear. Everything will happen the same, except you'll be going backwards.
How is this relevant to anything discussed above?
post #9 of 12 (permalink) Old 04-19-2011, 03:25 AM Thread Starter
hahahah... you must read... before you write.
Clutch start? Who said anything about a clutch start?
fail.
post #10 of 12 (permalink) Old 04-19-2011, 03:57 AM
It's a scammer. Don't listen to anything he says. And DON'T click on the link in his signature.
Reverse Gear vanctour W245 B-Class 29 11-14-2009 05:39 PM
Reverse gear doesn't shift aqirjazi W202 C-Class 1 10-07-2009 02:43 AM
95 E320 Cabrio. Reverse Gear stop working emad166 W124 E,CE,D,TD Class 4 07-28-2009 01:49 PM
Reverse Gear TexasTJ W124 E,CE,D,TD Class 4 08-09-2008 03:44 PM
Reverse gear - vibration ? Kirill R170 SLK-Class 8 04-21-2004 08:17 PM
