1994 MB S350 TD Cruise Control Problem - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-10-2011, 07:41 AM Thread Starter
Date registered: Mar 2011
Vehicle: 1994 Mercedes S 350 TD
1994 Mercedes S Cruise Control Problem
Yesterday I was Driving back home and like always I set the cruise control but this time something went wrong with it. I called my Mercedes guy and he said it was electrical, but I am thinking it is vacuum related. Everything with the vacuum system works except the driver side door locking system.. (But I Can Hear A Leak) So, I was just wanting to get some reasons 4 my Cruise Control to be acting up? So if u can, Please give me a opinion 4 this malfunction. Thank U.
TyFitch16 is offline
post #2 of 2 (permalink) Old 04-11-2011, 08:19 AM
Date registered: Nov 2008
I had the same problem with my ML320. The cruse control would not activate. I'm not quite able to tell if this is the same issue, but here's what was wrong. The brake pedal has a switch that 'open' when you press it to activate the rear lights. It failed, so not only where my brake lights always on, it gave the cruise control the information that the pedal was depressed and would not allow it to come on. The switch was 22 dollars and took about 10 minutes to replace. Check the rear of the car and see if your brake lights are on all the time. Hope this helps. Gus
roguern is offline
    Cruise Control Problem bhavick C209/A209 CLK-Class 8 05-06-2015 08:48 AM
    1994 MB S350 TD Cruse Control Problem TyFitch16 General Mercedes-Benz 0 04-10-2011 07:40 AM
    Cruise Control Problem JoeBobBenz W123 E,CE,D,CD,TD,TE Class 2 04-20-2009 11:28 AM
    Cruise control problem dlbehrns C208/A208 CLK-Class 0 08-18-2005 08:40 PM
    Cruise Control Problem DUTCH G-Class 20 08-02-2004 05:45 PM
