E320 CDI judders when accelerating - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-09-2011, 05:24 AM Thread Starter
Date registered: Jun 2008
Unhappy E320 CDI judders when accelerating
Hi All,
I'm new to this post and need some help with my Car, it’s a Merc E320 CDI 2003. Hope someone can help me out.
The issue with my car is, it judders when you accelerate. The car wants to accelerate but something is holding it back.
I popped round to the local Mercedes garage who said they need to do a Glyco test at £189 + VAT. From here they might know what the problem is or do some more tests at additional cost.
Reading form other forums there seems to be a fault where coolant can get into the Gearbox or transmission oil.
They said if this is the case I'll need a new Gearbox or transmission. Which i'm sure will cost alot.
I have a few of questions about this.
Can anyone else do the Glyco test and how much does it normally cost?
If this is the case, will this not be a design fault in the car and should come under warranty. I tried to argue this case and the only reply i get back from Mercedes is "My car is over 5 years old and not covered now". They refused to accept it's a design fault.
Also if this is the case, won't changing the oil stop the juddering for a while until the problem is found and fixed?
Also, what will need changing and how much will it cost. Is there anyone near Preston area who can do the work?
Is there anything i can do to prevent this?
thanks in advanced
c1immy is offline
post #2 of 3 (permalink) Old 04-11-2011, 05:45 PM
Date registered: Apr 2009
Vehicle: 1999 E300TD
immy, this is a somewhat common problem. The transmission cooler is built into the radiator and it does leak and the coolant will mix with the trans fluid. You do need to have a glycol test done. We do it with a merceders kit, but im sure there are other cheaper kits available. If they did mix you need to replace the radiator and do a full transmission flush. Ive done a few and this has worked if its caught in the earlier stages. you can call the mercedes cac (customer assistane center) and complain and see if they can do anything for you
saleen1276 is offline
post #3 of 3 (permalink) Old 04-20-2011, 02:15 PM Thread Starter
Thanks for your replies. I'm thinking i'll first get a transmission flush, it won't cost much from a local garage i know very well. See if this will stop the juddering temporarily. I'll get the Rad replaced later if the issue comes back and at the same time flush the fluid again.
c1immy is offline
    Judders over 60 mph BishopsBenz W203 C-Class 2 04-11-2011 08:11 AM
    96 E320 not accelerating past 35mph HELP !!! mercedesgullwing W210 E-Class 10 10-25-2010 07:45 AM
    GL320 CDI - automatically accelerating westiegirl General Mercedes-Benz 0 01-08-2009 03:00 PM
    94 E320 not accelerating 94dawgfan W124 E,CE,D,TD Class 19 01-05-2009 01:56 PM
    2000 vito 113. judders,misses, no power!? jobo V-Class 2 12-03-2007 02:39 PM
