300E 1992 running at high temp!!! Help needed - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-05-2011, 06:29 PM Thread Starter
Date registered: Nov 2009
Hi, I'm new here and english is not my mother tongue, but I'll try. Recently I bougth a inmaculate 300E with only 84.000 kms on it. Everything works perfectly unless the engine that seems to run at very high temp, (about 110-115 degrees). Specially during heavy traffic, the fans will come on and the gauge goes down to about 95 and again will come ut again, and so on. When driving in a highway the temp remains at about 85 degrees. I have checked the thermostat, changed the fan clutch, checked the radiator for leaks, (has none), and the electric fans work fine. Can any one please give some advice? Thanks!!!
001425 is offline
post #2 of 5 (permalink) Old 04-05-2011, 06:30 PM Thread Starter
I forgot to tell the car has automatic gearbox!!
001425 is offline
post #3 of 5 (permalink) Old 04-05-2011, 06:34 PM
Date registered: Apr 2011
Vehicle: 1987 300 E
Send a message via AIM to maarnold Send a message via Yahoo to maarnold Send a message via Skype™ to maarnold
my 87 300 does the same thing, as did my previous one. any answers?
maarnold is offline
post #4 of 5 (permalink) Old 04-05-2011, 06:36 PM
1984babybenz's Avatar
Vehicle: 1984 190D 2.2
110 degrees celcius?
When is the last time you have done a coolant flush?
You can buy a thermostat that engages at a lower temperature if you want.
1979 Pontiac Firebird 5.7- 86,142 miles
1981 Chevrolet Corvette 5.7
1984 Mercedes 190D 2.2 Auto - 140,628 miles
1987 Chevrolet Sprint 1.0 - 139,000 miles
1989 Oldsmobile Cutlass Calais S - 123,000 miles
1989 Chrysler New Yorker - 95,000 miles
1991 Dodge Stealth R/T - 101,000 miles
1999 Dodge Durango - 178,000 miles
2003 Dodge Dakota - 203,000 miles
1984babybenz is offline
post #5 of 5 (permalink) Old 04-06-2011, 05:28 PM
Vehicle: 2005 C350, 2002 ML270CDI, 1969 230S, previously 2002 A160, 1985 380SEC ivory, 1983 380SEC grey
Hi '1425,
I had a similar problem but with a much older car, a 1968 230 'Automatic'. I had the temperature guage and sender unit removed and checked for accuracy. It was reading slightly too hot, but not much.
It turned out to be a substantially blocked radiator, due to a recent cylinder head repair. The usual crud etc inside the engine block had dried out during the repair, had come loose, and promptly blocked the radiator during the first few hundred miles.
I suggest that you get a flow test done on the radiator.
Another thing to look for would be collapsed hoses. Sometimes they delaminate internally, effectively blocking circulation.
Your symptoms appear similar to mine, in that the temperature was OK driving at moderate speeds, but overheating in slower traffic.
All the best
David
Audiophile_AU is offline
    1986 300e idle running high but becomes okay when.. ceasterly General Mercedes-Benz 1 10-28-2009 02:55 PM
    1992 500SEL operating temp 550maranello W140 S-Class 5 07-03-2009 01:02 AM
    1992 300E transmission in a 1993 300E 2.8 M104 engine? abiez W124 E,CE,D,TD Class 2 03-17-2009 11:17 AM
    1987 300E hard to start at running temp DADARKPRINCE W124 E,CE,D,TD Class 3 10-10-2006 03:49 PM
    300E Running at High Temp Fan Clucth and Heater Core Problems Khizer W124 E,CE,D,TD Class 9 09-25-2003 08:58 AM
